As mentioned in another post, I had a brand new moment but the screen had light bleeding so the dealer was more than kind to offer a brand new " inspected " beosound moment.
Eagerly waiting to start it up at home, it was much of a disappointment. The jukebox won't connect to server to check for updates. I tried to restore to factory settings but I was stuck at can't connect to Beoportal.
I did a soft reset, it went into the configuration menu but the DLNA option is grayed out although both my TV and PC can see all available DLNA servers.
I still cannot check for updates eventho I did a factory reset. I'm clueless and not sure what to do. The dealer is really far so can anybody assist me in troubleshooting the DLNA thing ?
Also is it normal to have a jukebox with serial number : 0000000 ?
