Hi all!
I have a setup with BV3-32 and BL8000 as front and BL6000 as rear speakers in my living room.
When I turn on the TV, I have setup the TV to turn slighty to the right to optimize my viewing position and sometimes, it seem when the speaker cables moves with the TV and touches eachother I get a loud cracking, electrostatic noise.
The same fenomenon happenens when touching either of the four signal cables, but usually I can get rid of it when moving them carefully to a spot where the distortion stops. It is extremely sensitive and happens from time to time since I like to use the motorstand.
The cables are fairly new ( and I get the same problem with my AV 9000 with BL 5000/BL5000 from time to time in my bedrom, connected to a different power circuit) so I doubt it is a cable issue.
Does it have something to do with the grounding? I have used a long powercable from my ktichen that has ground in it, but I also have a lot of stuff on the same circuit ( BV3-32, BL8000, BS2300, BG3300+RIAA, DVD1, Apple TV, Cable Modem, STB, Apple Airport Extreme, External HDD, is there something in here that might cause the problem?) The rear spears BL6000 are on another, non grounded circuit.
An electrician friend of mine said there might be some bad grounding in the house, that its actually "leaking" power...
Any ideas, tips and tricks are welcome!
/Peter
