Eject DVD1 via Beo4
Hi All,
I was just wondering if anyone knows of a way to eject a DVD from a DVD1 via the Beo4?
Try holding stop for aboput 20 seconds or so, it works the avant dvd.
one other thing why would you want to do this ?
beolad
Have tried holding eject but no joy!
I just wanted to know if it is possible thats all!
It would also come in handy those few times someone else is doing the disc swapping but can't find the eject button on the front of the DVD1 without their glasses
Eject? I was not aware that the beo-4 had this button?
mmmmm interesting
Apologies, I meant 'Stop' rather than eject!
Any thoughts BeoLad?
Have you made sure that the active source was the DVD player.
Press STOP to Pause the DVD, then STOP again to stop it, then press long time to eject it.
This might not work on all the DVD players/Beovisions.
P.
Thanks for the advice Phil but no joy!
I have made sure that the Beo4 is always in 'DVD' mode. When I press stop it pauses, stop again and it stops, press and hold a third time and nothing happens (other than a cross appearing on screen to signify that the command is not applicable).
Any other suggestions chaps?
You can - with Beo5😕
mr anders son could you explain how it is possible with the beo 5 ?
And if its progammable why couldnt this be done to a beo 4 ?
dredged the net and i'm really sure you can't eject it using the remote - i suppose the theory is that you have to 'attend' to the unit anyway if you intend on ejecting a disc you want to insert or remove so no need to have this function...
