I am considering replacing a 32 Avant, currently in a corner position in the bedroom, with a wall mounted TV.
The BV10-40 with possibly a BL11 is an obvious contender, but a used Beovision 4-42 might make a good alternative. (I have a behind-wall space for the Beosystem 2.)
I am not too worried about HD broadcasts as I've found that the BV5 gives stunning results with SD and assume the BV4 will be similar.
Does anyone else have views on the BV4? Should I be worried about an eventual move of most broadcasting to HD? Related to this last question, do any set top boxes convert HD broadcasts for viewing on SD televisions (as opposed to upscaling SD for viewing on an HD TV?)
Speaker- wise, would a pair of BL8000's provide convincing front speaker performance without the use of a central speaker?
BV10 plus BL11 or BV4 and BL8000's. Which is really the better choice?
Graham
