Edge and Chromecast
Are you 100% sure that you, at work, are playing via Chromecast and not airplay?
From the Spotify website:
Want to play from your desktop?
It’s not possible to find a Chromecast device from the Spotify desktop app, but you can still use it to control the music:
Launch Spotify on Chromecast with your phone, tablet, or the web player following these steps.
Note: Chromecast is only compatible on the web player with the Chrome browser.
Use the desktop app to control your listening.
https://support.spotify.com/is/listen_everywhere/on_tv/i-cant-get-spotify-to-play-on-my-tv/
tph wrote:
The difference is, Beosound 2 supports Spotify Connect, Beosound Edge does not.
— Tuomas | Bang & Olufsen CREATE
So most likely moxxey is connecting, not casting.
Oh FFS! That's not good. Such a shame. Was hoping it would perform exactly like the BeoSound 2.
Yes, that's what's happening. It's using "Spotify Connect" which is stated under the 'Beosound 2' name under a list of devices in Spotify. So only the iOS devices use Chromecast.
I always thought "Spotify Connect" was using Chromecast to make a direct connection to the speaker.
You are being gracious.
Spotify has its own protocol, called Connect.....which has nothing to do with CC or AP(2).
Just like the M3, the Edge has no support for Spotify Connect....neither has the Balance.
P.S.
It was mentioned, that the Balance will be updated for Spotify Connect
This might (?) create a hope
Hi Thomas. I can’t use Spotify connect with my beosound 2. It uses google Cast instead. Can you verify the Spotify connect?
