Edge and Chromecast
Maybe this is something I'm overlooking, but I bought an Edge the other day, set it up with Chromecast, but it doesn't show on Spotify as an available speaker on my Mac.
The strange thing is, it shows on the iOS version of Spotify, just not the Mac or Windows 'desktop' version of the app?
More strange still, my BeoSound 2 appears on all versions, iOS, Windows or Mac. It's just the Edge that doesn't appear on the desktop.
Any ideas?
Check where you usually find airplay.
You usually can’t start casting from a computer. You can start from an iOS device and then control it from the computer. But it has to be initiated from a mobile device.
Tried this, makes no difference. The Edge is available through Airplay and Chromecast on the iOS devices and can be played, but quit those and switch to the desktop and the Edge isn't listed as an Airplay or Chromecast available device. BeoSound 2 is, however.
Why would the BeoSound 2 be listed as a Chromecast 'available device' but not the Edge.
Perplexing.
yep, makes no sense.
both my BS2 and A9 mk2 are visible from laptop.
Perplexing.
What Chromecast versions are your products on?
Is this on the spotify desktop app? Only spotify connect devices show on the desktop annoyingly, unless you start streaming to the chromecast device from your mobile first. Perhaps the beosound 2 has spotify connect built in and the edge doesn't?
Rob.
Rob.
This is what I tried to explain, so I will continue on yours, Rob.
When you are connecting from the iOS app, you can choose if it should use airplay or Chromecast. You can click the icon and change what it uses as standard. This is actually a pretty smart feature.
You cannot initiate a cast from Spotify in a pc or mac.
Yes you can. I do it all the time with my BeoSound 2. That's my entire point.
From my MacBook, at work, I can open Spotify, select the BeoSound 2 and play via the desktop version of Spotify via Chromecast....no iOS involved and not needed to initiate.
So how can it work with the BeoSound 2, but not Edge?
The difference is, Beosound 2 supports Spotify Connect, Beosound Edge does not.
Human interface designer at Bang & Olufsen.
