I don't know if this helps but it talks about having to re-calibrate the stand after moving the TV (Moving = unplugging I assume)
Devon,
UK
With the older TVs there was something about having to plug the stand in either before or after powering on the TV. I had the issue with an MX 8000 and I'm almost sure you had to plug the stand in after powering up the TV for the stand to be recognised..
So long ago I can't remember.
Stoobie
Did you ever get this resolved?
its the dsse board in soundcenter thats is faulty
you can check that in menu service advance diagnosis
if 12v is 0 and red its dsse board
but to the connection of stand no matter of model
the stand cable have to be connected then tv is
unplugged from power otherwise the stand
never be recognize
