Eclipse Stand
Hello all
Today I went to look for the stand option saved in my TV and it was not on the remote.
I looked on the TV and no stand as in the menus it has gone.
Any ideas?
I unplugged the stand and put it back in but it’s completely missing.
I used it about a week ago and it was fine.
Any thoughts ?
Anyone know what the latest software is?
My stand seems to be missing and I wonder if it’s one of the latest updates floating around we keep seeing on here.
3.0.40943.163635848
Eclipse 55 MkII here
Software not updated as it’s the same as Erik’s
Damn it
Eclipse Mk1 55
Software Version 2.7.37196.117795280
(Not sure if there’s any regional differences, but based in the UK)
Matt wrote:
Eclipse Mk1 55
Same version on my Eclipse Mk1 55 (in Copenhagen)
Best regards Dyssegaard
Seems as my TV software has not changed.
I will as a next step factory restore it today to check if it comes back.
Cheers
Sean
Hi, it might be an issue with your BeoRemote.
It has happened to me a couple of times before. Just pull the batteries out and put them back. This will force a new pairing (done automatically, according to the instructions my dealer gave me back in the day) and the Stand option will be in the List again.
Hi there
It’s missing from the TV also [:\'(]
It’s not there if it doesn’t sense a stand being present. Can be a cable break or maybe something died?
