Eclipse speakers
Am I right in thinking there are Beoplay speakers that can play what’s on my Eclipse. Ie I’m watching tv and I wander into the kitchen, can the speakers pick up what’s on the Tv as a group etc?
Yes! All multiroom-enabled speakers (A6 / A9 Mk2+3 / M3 / M5) can achieve that. And the BeoSound 1 / 2 / 35 / Shape / Moment / Essence / Core) too.
There is a slight delay between the eclipse and the NL speakers. Not a big deal if the speakers are in a different room, but annoying if you hear both eclipse and speakers at the same time.
That sounds a bit rubbish if I’m having a party, and I want music streamed through the house. I’ll have to pop in and check.
There will be no delay for music, only for live television broadcasts.
It's all in sync with music I use this feature a lot, both for music and television.
You have to change the msec delay in the app and it should be in sync.
