Eclipse speaker settings
Hi
Happy new year
I have a beolab 2 connect to the eclipse but it does not turn on ?
Its set up in speaker roles /speaker levels but when I come out of the setting and watch tv the sub turns off ?
any idea please
Happy new  year,
do you use the speaker Connection?
Sorry my dumping question, only an idea, because the connection board has two rows of connections, one for the PUC connections and Mic, the other for the Beolabs, please make sure, otherwise set up as described in the operating instructions.
CU
Ingo
When I use the speaker roles set up,I can hear the beolab 2 so I am sure they are connect properly.
O. K.
The manual says:
 Disconnect all systems from the mains before you connect additional products.
Then it’s not configure in your speaker preset to be the sub or to be on.
The Illustration in the manual shows an example of a speaker setup with two front speakers, two daisy-chained rear speakers and a subwoofer.
Can you choose the Beolab 2 in the Setup?
Yes and I can her it
Go to the speaker preset menu where you can set the roles of your speakers and set the bl2 to on as subwoofer. It’s mostlikely not switched on in the preset you’re using(start up)
Do you have other speaker Connect to eclipse? Or only tv speaker and beolab 2?
