Hi Beoworlders,
I currently own an Eclipse 55 mk1 and although I’m very impressed by the overall performance of the soundcenter, I’m currently looking into my options expanding my setup with a set of Beolab 18’s.
my question however, should I consider adding the Beolab 19 as well or does Eclipse + 18’s deliver enough on bass. Will the 19 be a bit overkill? My livingroom is about 45 sqm with a wooden floor
I normally don’t play music/movies above 50, but I remember hearing the 18’s by themself in the store and felt it was shortcoming in the low end frequency’s. The other option would be to upgrade directly towards beolab 28 as I’m reading some good feedback about them here on the forum. Although that will set me back about double the money.
Also on design I’m not really sure if I fancy them as much as the 18 without the acoustic lenses. Beolab 20 may also be an option however regarding design they look a bit boring to my taste.
Anyway, I’d love to hear your thoughts.
regards Alje
