Eclipse Soundcenter and OLED Panel Compatability
Good day all,
I have not kept abreast of some of the previous threads and the rabbit holes the discussion goes.
Concisely, does anyone have a view on the inter-compatibility of the Eclipse Soundcenter and that of either 3rd party OLEDs or LG OLEDs?
1. What does the Soundcenter do? Sound, Sound Processing/Beolink etc....
2. Does the Soundcenter handle programming etc.? I tend to think not?
3. The connections between the Soundcenter and Panel seem to be Industry standard. So is the electronic handshake anything special?
4. I am not concerned over the mechanical fit
Any thoughts would be welcome.
10
The Eclipse Soundbar works with LG G1 and GX panels through the eARC protocol. The B&O app gets installed on the LG TV and this is how the TV and soundcenter communicate.
1. It works as an AV receiver, process audio signals and them to speakers. For more detail see:
10
This guide - in form of a pdf 🙂 - might give you more information:
The two responses so far....
1. Confirmed my technical suspicions with the roles of the Center and the panel.
2. i.e. the Center does not project Beolink/BeoApp function onto the screen but is instead handled via a discrete App in the LG smart TV
3. This could strongly suggest (depending on hardware/software access or locking) that the Center will work with any LG smart TV?
No, this is not the case, Only C, G and Z series.
But yes there should not be any problem in buying a Eclipse sound center, and get it to work with a 83" LG C1 OLED,
To my understanding most of the remote functions actually go theought the ethernet side of things. If you don’t connect an ethernet cable between the panel and the soundcenter the remote does not function. This is the same for the stage if yoy wish to use a beoremote 1
That is readily done via the Center and the Panel (LAN/CTRL) Socket.
Ok, it’s just an fyi for the general question how it works with other panels or even lg panels. As for LG i think, if i remember this right, the lg panel also needs an alpha 9 chip or higher. That’s why a B1 panel doesn’t work iirc, because it runs on an alpha 7 chip. WebOs 4 is also a minimum iirc, but most if not all panels are beyond that now.
Hello there
Interesting topic, I am interested in if one day when the screen is no longer alive how I could use another panel with it as the sound C will definatly last more years than the OLED panel.
I am really interested with your mounting options and how it would fit in future.
Hi, this is my basic thrust of the thread. I have a Mk1 Eclipse 65, and although Im not anticipating issues yet, Im working up contingencies of "what if?"
I would be choked if B&O locked this screen into the Center and still kept the cr@ppy interface (worst of both worlds).
Mk1's are worth 2/5th of nothing on Trade-ins and this time around....I'd be damned if Im going to throw 12 grand at the same problem again and a replacement screen I believe is near to 5k on its own.
