Eclipse screen fault
Any ideas why this green line is suddenly appearing? Login to view image
New colour.... š
Looks like a panel fault. Does it do it on all sources?
One thing you can try is do a panel refresh cycle, the sun can sometimes cause artifacts that a cycle like that can fix.
It does this on all channels and all sources. The sun never comes near the screen.Thanks for your replies
This may help you?
Thanks. It mainly looks at input sources which are all different but all display the error. Iām 4,000 miles away so in just passing on second hand info.
Faulty panel, which will be replaced under warranty. Thank you Cheltenham for your prompt professional response.š¤
Register to access the forums, reference material, and exclusive member benefits ā including our monthly prize draw.
