Eclipse picture settings and ATV
Do the picture settings in Eclipse settings automatically apply to my attached Apple TV, or is there somewhere else where I can tweak the picture settings for Apple TV alone?
You have to do the picture settings to you your likings in the picture settings of the screen.
Nothing is done automatically for the Apple TV.
You can choose if the settings you do should apply to that input only or for all inputs.
Very helpful, thanks. So how do I choose which sources the settings should apply to? And if I want to apply them to all sources?
If you - or someone else - are not aware of this, there are some B&O recommendations for the picture settings for the LG tv’s here (the second half of the video).
MMlink
All sorted. Thanks
When you have your Apple TV visible on the screen, it is that input you apply changes to.
In the menu (you can see that in the video Millemissen linked to) you can select if the settings should apply to all inputs.
https://youtu.be/soABokgnIlE
Thanks for the info MM - I have changed the picture setting on my Eclipse accordingly and the color temperature is now just as fine as on my good old BV11 🙂.
Best regards Dyssegaard
