Eclipse enters standby automatically
Ever since I changed the region setting from EU to US, my Eclipse switches itself to standby every so often. It happens on several sources and I have not been able to find a red line here. I can switch it on and it comes back as if nothing had happened but it’s annoying to have a movie cut off in the middle.
does anyone else have this problem?
The first step is to find a perfect and professional realtor who related to finding your dream place. The step to be a nice manner to find a good realtor like and others for your area is with the help of referrals
Hi
TV Powersetting ecomodus is off?
Looking for a timer, sleep timer is off?
Ingo
Beauvais: I doubt a realtor can help fix my TV. Jeez
I have gone through the TV menus and turned eco things off as far as I can tell. Sleep timers are also off. Having said that, I may want to check the service menu of the LG unit, as it lists more details than what is visible in the user menus. The problem is that these service settings are not individually changeable, but they seem to be set by whatever Region/Country code you enter for the TV. I recently changed my Region code from EU to US, using the code listed in the Eclipse service manual, so it should be OK, However, this is what the problem started.
The reason I changed to US region was to be able to access the LG Store contents. I have now installed the YouTube TV app, which I am using for live TV), and I think this app is the reason that the LG unit sometimes freezes. Sound stops, picture freezes and the only way to recover is to pull the power cord. I am pretty sure I have seen the annoying auto-standby using other apps, so I will only blame the YouTube TV app for the LG freezing problem.
the freezing problem can also be an issue off the hdd, if you connectet one
The usb cable please without an extension cable, if the hdd is more than 1000MB, ist is better to use one with  extra power adaptor
Ingo
Ingo wrote:
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
I have a 1TB HDD connected with USB only and no problems whatsoever.
Sorry,  you are right, I mean 1000GB.🙂
But my dealer told me that 500GB was the limit that the hdd works flawless.
 Ingo
I had a 2tb drive over usb only, no problem with eclipse or harmony
