Eclipse 65" and Apple TV 4K
Hello folks,
I got a Beovision Eclipse 65" (1 month old) with a Apple TV 4K.
I got the TV installed and I could controll my Apple TV through my BeoRemote One (without Netflix) and everything worked fine (there was a second delay switching from side to side on the Apple TV, using the BeoRemote).
But recently I changed the HDMI cable from HDMI A in the Eclipse to the Apple TV 4K (there was a defect on the HDMI Cable, which kept saying there was no HDR signal, and I couldn't watch specific programs).
Now I got it changed, and I press "TV" on my BeoRemote one, and Apple TV still appears, and when I click "OK" the TV turn on, and starts on Apple TV as I should, but I cannot control the Apple TV/menu on the BeoRemote one, as I could before.
I've tried to connect my Apple TV with the beoremote one in ATV settings (bluetooth) and this gives me a new setting on "list" on the beoremote, but this only allows me to use the Apple TV, not change the volume, shut down the TV and so on..
So the big question: How do I set it up,  as it was before? Everything seems to be set correctly (Also the control ATV through HDMI in the settings), but still do not work.
This is my setup and all works fine.
