Ok here goes. From left to right the original Ear phones A8, an updated version still Bang & Olufsen branded, and the last one is the Beoplay EarSet 3i for iPods and iphone.
I think the middle one might have come with a Beosound 2 or 6 MP3 player that was later sold, as I dont seem to have a manual/guide for that pair.
Build quality and sound wise I haven’t noticed much difference. The middle pair seems a little loose in the vertical adjustment, but that might be because it was used more than the others.
As seen on the pictures the earpieces seems identilcal except for the Bang & Olufsen and B&o logos.
As mentioned in my earlier post the cable junction is different on all three pairs, the connecters was identical except for the 3i had 4 connections in the minijack as it is a headset. I have replaced the connector on that one at some point cause the wire was broken.
The 3i if course has the control buttons for volume and an universal play/pause or take call/hang up button depending on what is active on a iPhone
The original A8 was delivered with a black leather purse with Bang & Olufsen engraved, and an extension cord for usage with a TV or a music system so you could have some distance.
I didnt have the best lightning conditions for the pictures, but I hope you can see enough.
Login to view image Login to view image Login to view image Login to view image Login to view image Login to view image Login to view image Login to view image
