Early ir eye help
I have this IR eye and I cannot understand the wiring. All I know is that it was used in a setup with a BS9000 mk1, so it is from that timeframe. Any help on this? I want to use it with a Beosystem 3. Login to view image
Ports are marked (from left to right)P1-1, P1-2, P2-1, P2-2, P3-1, P3-2
I am not sure what IR eye that is! AFAIK all the B&O ones have either 5 or 7 terminals. Perhaps look for a part number and/or post a picture of the front.
For BS3 control, have a look at this thread:
Regular front. Only number on that snide is DPD 9405 Login to view image
Is one of the terminals a dummy - i.e not connected to anything?
Not sure. Will check later this evening 🙂
