Hold on. First an A9 MK4 now a new E8 and E6 Motion?
E8 and E6 Motion?
Saw that on my Google feed... apparently it's IP54 rated for moisture resistance, which I guess is what they meant by 'physically' updated (according to the article I read). "Digitally" updated also seems to simply point to a new profile in the app, which supposedly has enhanced bass.
The E6, as it goes on to explain, has a "splash resistant rubber cord", although I'm not sure what it was before, but if it's anything like prior Apple TV power cords, rubber may just accumulate unsightly dust.
All in all, it seems more like a superficial update to me.
I think you misunderstood. We can read what it is and achieves, itβs just that B&O is suddenly adopting a strange habit of making a new launch, then updating the same product with new features only a few weeks or months later. E8 2.0 has only recently been released.
The Motion version is ideal for me as I mostly use the E6 for running or gym. And I sweat a lot!
My fault. The article I chanced upon seemed to have details that weren't mentioned in the T3 article.
Anyway, I was going to mention that unless you were seriously using it for active [workout] purposes, I wouldn't sweat it..... but I guess this one actually hits the nail on the head for your circumstances.
And yes, I am just as confused as many about these untimely updates. Not sure if it's a strategic move on their part or what. My fear is that they may just be 'panic releases' to get the brand in the 'what's new' sections of tech blogs.
Yep. I just can't fathom why they couldn't have built in the 'Motion' support in to the E8 2.0 which was only just released! Perplexing.
I do like the E6 Motion in White. I've just bought a new pair in Sand π
Find this a bit strange as well. I guess for the E8 the only difference appear to be the "fins" and the color. I bougt the E8 2.0 in natural color and will see if its possible (wich I assume) to buy the fins separately. The earbud looks the same so the fins should fit.
To be honest it looks like a marketing stunt. How would these be more sweat proof than the regular one? They are filled with glue anyway.
It really is difficult to say, you're right. They look like they have additional rubber rings/seals added where the cables connect to the plastic components? But if you look at the E6 specs, they say "Splash Protection: Yes"
Could be marketing. I do note the E6 Motion isn't any more expensive than a regular E6.
I also think the "limited time" component points toward just marketing. Sure, B&O builds limited edition products with new/different colors, but additional waterproofing seems beyond a new color. Why build a "limited time" product vs. a limited time packaging / new ear pads?
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
