DVD2 won't recognize my Beo4 remote
Is the SCART cable fully wired? Some of the cheaper ones are not, yet the B&O data requires extra pins to be connected to pass data to/from the DVD2. Your symptom would suggest this as the cause.
See here:
Thanks for the quick response Guy.I don't know if the cable is fully wired, but I can see all 21-pins in the plug.
Do you suggest that the DVD2 wouldn't get IR-signals through HDMI? So the only possible connection is a fully wired SCART-cable? 😂
Often SCART cables have all the pins without them all being connected - best to check with a multimeter.
And yes, I understand that the DVD2 must get IR signals via the SCART and not the hdmi. Old technology I know but it should work!
Further to my last, one thing that I didn't realise with the DVD2 is that there are 6 recessed buttons on the back (under the hdmi socket) that enable you to control the player. So at least you can test if it works!
From the service manual (available if you upgrade to silver) they are:
S1 Open / Close
S2 Next
S3 Standby
S4 Record
S5 Stop
S6 Play
And a search of the old forum gives this useful answer: /forum/general-discussion-and-questions/mmc1-vs-ortofon
Thank you so much Guy 🤩.When i get home from work, i will try to test out the 6 buttons on the back as you suggested, and then I can buy a new SCART-cable afterwards.
Happy that the unit was cheap, when I have to use SCART 😂.
No problem - happy to help! And my only TVs are BV6s hence SCART is being used widely here! 😁
Were you able to get this to work, and if so, how?
