From the DVD2 playing if I switch to say DTV or The Humax Free sat box the new source shows on the screen, with the DVD still "spinning" then if I power off with the Beo5 the DVD2 doesn't go into standby mode (everything else does), but if I play the DVD2 and power off with the Beo5 it stops and goes into "red" standby mode.
Also the DVD2 doesn't have an on/off switch,
and when altering the on screen connections and switching sources and powering off the whole system sometimes freezes and because there's no on/off switches i have to pull the Beosystem's power lead, (not good)
I will try it again and see if it turns of and goes into standby after 15 minutes or so
