DVD2
Has anyone bought a DVD2 yet. I would love to know your thoughts..
jazz
Yes I got him....
I just have it for same day's and it is a complicated DVD-2 player. To work with the DVD section, it is great, really easy to use. I got a DTS in the avant RF and I think that the sound quallity is better than the DVD-1, but again, this is what I think.
To work with the hard disk, that is a other thing. You have to programm the hd and that need some time, now I have add the Sat reciver to the DVD-2 and now it becomes tricky, can not find out how to add this correctly.
One thing, it takes 40 sec. when the DVD-2 is ready when you start it from standby till playing a dvd, so... that is all..
I am trying to write something about the DVD-2 on the forum, I do not know when..... who tells 😂😂
Ehhh here is a photo of the
It looks good.
40 seconds to start up is far too long though. I understand that it has to "load" the hard drive... ,8,1 (some of your will remember this....lol) Why should you have to wait that long just to watch a dvd.
Please let us know your thoughts when you start to make timer recordings with it..
jazz
40 seconds is the time the DVD-2 needs to start the hard disk.. I know it is a long time... but its works nicely
About the program ore timer: you can programm the HD in many way's, one of them is by showview and manual... I like manual. You do not need to read the manual that good to understand how to set the time to record a programm, it is very easy.. even I know it!
I can say that the sound and picture quality is better than de DVD-1 and that is good...
Can you timer record from a satellite channel?
There is no STB-controller in the DVD2
Here is a workaround,
Most set top boxes have 2 scarts, so you can connect one to the TV and one to the EXT1 socket of the DVD2.
You can programme the DVD2 to record at a certain time from EXT1, and - separately- you can programme the set top box to tune to a channel at a certain time, using the set top box own scheduler.
The Good:
  • It should work, and all with the Beo4
The Bad
  • it is not elegant,
  • it require the 2 clocks to be in sync,
  • it does not "lock" the channel on the set top box, like another recorder would do,
  • it will not allow recording of the DVB module in the Beovision.
p.
Beautiful design though, and the cabinet quality is stunning! Not too sure about the innards at the moment, but I don't have much experience with the DVD2. Didn't seem too user friendly when I first had a play, but I probably just need to play with it more!
Overall though, beautifully finished, and absolutely looks the part.
Hello,
since 3 days I am also a owner of a DVD2.
I have a BV6.22. The first scart is connected to a Beocord V8000 via a Samsung Digibox. In the connections menu (VTape + STB). The DVD2 is with the second scart connencted and as VAUX in the connections menu registered.
If I look TV via the tuner of the DVD2 and want to record a programme always the V8000 starts and I cannot rrecord to the harddisk.
How can this be fixed. Any ideas?
Beoraki
