I found this on the Beoworld product page for DVD 1, where it states how to change the region code;
"NOTE: This method does not make the DVD1 Region-FREE. There is a limit of FOUR changes to the product over its lifetime (without professional servicing.) USE THIS INFORMATION AT YOUR OWN RISK.
Remove any CD or DVD and disconnect the power.
Press and hold << and >> on the front panel (not the remote) while reconnecting the power plug.
The current setting shows on the display.
Use << or >> on the front panel (not the remote) to change Region number.
Press PLAY to store. Wait 15 seconds until TV screen shows blue."
Reference: http://www.beoworld.org/faq_view.asp?id=78
I tried this procedure and nothing came up on screen (it's a MKII dvd1). I think it is in region 0 mode, but it only plays half the region 4 discs i play.
How do you change the region on a DVD1 mkII? Can any body help me? Please!
