DVD1: Power light enable/disable
I have two DVD1 players. On one, a red dot lights up when it's powered. On the other, the display remains blank (black) unless a DVD is actually playing. Is the power dot enabled through a configuration option?
Mark
If they are Mk1s (Type Number 4620) then on the Functions menu there's a 'Low Power Standby' setting (ON or OFF) - try toggling that.
Looked like a good idea, and they're both Mk1 players...
The one where the power indicator works was set to "off" whilst the one where it never comes on was set to "on". However changing the flag had no visible effect on either DVD1 front panel 🙁
So thank you for the idea, but sadly it didn't solve the problem!
Mark
Great news - thanks for letting us know, and well done for fixing! 🙂
