DVB-C on BeoVision 7-40 with DVB-HD module
I've noticed that the latest BeoVision 7-40 user-manual, which can be downloaded from the Bang & Olufsen website, now also refers to hooking up a DVB-C signal.
Does this mean that when I add the DVB-HD module to my existing BV 7-40 it will become possible to use the built-in DVB tuner with a DVB-C signal?
Kjeld.
Hi Kjeld
That is absolutly correct.
You only need a CA-module and a card from your provider... (If you are from Denmark and have Yousee cable, you will not even need a card og a CA-module from sep 9.)
I use the DVB-HD module with Stofa and things are working ok. There will be an DBV-HD software update shortly that should take care of small issues.
Be aware that the CA-module requires a HDMI input in the tv.
That's very good news! I already have a CA-module (mascom AlphaCrypt) and card combination that I know works with my provider (Ziggo in the Netherlands); I've been using this with a Mac mini - Elgato 610 combination for several years now.
So I think I'll visit my B&O dealer this weekend ;-)
Hi!
Where is the slot for the ca-module located?
What are the issues that have to be taken care of?
Br
/hagan
