herwin wrote:
I have upgrades my Box without a problem and it does not crash anymore. I'm in Holland also.
About the IR transmitter, i have places several pieces of paper and now it is working much better. not 100%, it is still misses 1 of the 15 keys, most noticeable in Teletekst when entering a number. Up and Down almost go's ok.
and the GO - 1 (teletekst) and Go - 3 (DM Menu) responds much faster than Menu - 1 and Menu - 3
Thanx for all the help!
If you're almost getting there, you or some other "techy" guy, need to to fine-tune the damping factor of the IR-light.
Instead of putting a piece of paper, I would cut one of the two wires of the cable and put a resistor in the ir-cable. I guess you need to experiment with different values of the resistor, to get a stable workung PUC.
To get the right value, I would start with a potmeter, 0 - 10Kohms. Get it fine-tuned till it's stable, and measure the resistance of the potmeter.
Replace the potmeter with a resistor of that value.
