Dreambox with Beovision 10
Sinds a year i have a Beovision 10-40 wich i realy love
Now i want control my new Dreambox 800HDse (DVB-C) with the Beo4.
I have the latstest version of the BV10 software and 3 versions of the DM PUC codes.
Now my problem, the BEO4 is REALY slow ans loses lots of command to control the Dreambox.
I have tried 2 cables, differend PUC version, all 4 PUC ports, different locations of the IR sender.
What can i do to make it work?
thanx
Did you check the position of the ir reciever with a digital camera or mobile phone camera? This way you should see the exact position.
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
If you are using the PUC DM800 Vers. 2.00 set your BV10 to navigation button YES and use a Beo4 navi - 1710.
Does your DB work properly with the original remote?
Stefan
I have a 'old' Beo4 without navigation buttons.
right now i'm using the DM7000 PUC set.
Will check tonight de position, but i have placed them om several places, even 10 cm away from the box all with the same responds: slow and losing commands.
in about 2 weeks i will receive my new BeoVison 8-40 (new version) so i can also test it on this TV.
DM7000 codes should be the same as for the DM800. Does your DB work with the original remote?
Check your IR transmitter with a digital camera. When you press a button on your Beo4, you should see the transmitter flashing through the camera.
I have a DM800 SE connected to my BV7-40 controlled by a Lintronic box and it`s working great. But right now there is a sw problem with all E2 Dreamboxes - 8000, 800, 800SE, 500 see: http://www.dream-multimedia-tv.de/board/index.php
Stefan
The PUC signals every key i press on my Beo4. It is perfect to see on my mobile camera!
So i replaced the transmitter on the DM800 and its looks like it is working better now. The placement is very delicate..
Why do you use a lintronic instead of the PUC?
Thanx
I have the DM 800HD and the 8000HD.
Your problem is the ir-transmitter which sends a (to) strong signal to the receiver.
Take a bit of thin white paper. Place it between the sensor and the ir transmitter.
This makes the ir signal weaker, but the response far better.
Thanx! that works a lot better.
But it still misses some keys like the '0' and '1' in the teletexs, the 'Menu-3' for the main menu etc.
also with scrolling it misses soms ups and downs...
Keep experimenting.
Make sure you dont have a leak.
BTW beware of the driverproblem since 1 may. update you receiver with the latest software (after 1 may)
I'm using Pli. Backup your settings and update the software and afterwards reïnstal your settings.
I just got my Dreambox a few weeks ago, and the PUC list of my BV7 is not yet updated with Dreambox codes. I`m still waiting (again!) for an update of the BV7 software - because of a DVB HD modul issue. The Lintronic box is connected to the Scart plug of the BV7, so it is working just the same way as the PUC.
Have you set your BV10 to NO NAVIGATION BUTTON ?
Did you also try GO - 3 instead of MENU - 3 ?
For the sw problem of E2 boxes you just need to install the ipk file for your 800SE from DMM site and restart the Dreambox.
Stefan
