Doorr came off my Ouverture
The right door has come off  my Beosound Ouverture. Some places on the web says you just click it back on again, but that doesn't seem to be possible. Do I just clue it back on again?
Thanks in advance  Henrik
Pics please so we can see if it came off with or without the clips...
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
No clips on the door. Looks like there has ben some clue on the black bit, but before I do something stupid, I just need reassurance I can glue it back on.
Just take the clip off the Ouverture pulling it straight towards yourself. Then glue it back on. The residue of the old glue will hold it where it belongs. Did it this way myself a while ago.
Ralf
How do I upload a pic?
How do I upload a picture?
Thank you for your reply. I have just pulled them out and now need to stick them back on. The residue of the old glue is finished. Any specific type of glue or just the best superglue from B and Q?
A lot of people (including me) have successfully used Araldite 2-part epoxy in the past.  Available on
I used some standard superglue.
