BeoBiker wrote:
I am unsure if it is worth repairing. Is this a sign of future failure else where?
The first answer is absolutely YES.
Even if You wish to keep it, even if You wish to purchase something else, You need to repair it first, because without the repairment, You can sell the old system for almost nothing.
The answer for the second question is absolutely NO.
All CD mechanism and the lasers have a lifetime, but it does not affect the other parts of Your Beosystem (as You can see it). It's not the first sign of a wreckage (fe. in a car), but it's a simple "oil change".
How much difference will there be between the 2300 and 4?
First of all: Very much difference, because it will be a lot more expensive, mostly, if You wish to replace the speakers also. If You decide to change the Beocenter part only, than it will be far less impressive as a Beosound4 system, and You will lost also the beauty of a full Beosystem immediately.
In short words: I suggest to repair the BS2300 (first) 🙂
