Do i need a remote to change programs on my MX2000?
Hello all, I'm looking for a remote for my Beovision MX2000 TV. I've been able to use it so far through the antenna input and buttons on the top panel but want to be able to access the AV channels for use with my VCR.
I know most universal remotes won't do the work due to the frequency used by b&o but I just wondered if all b&o remotes would be backwards compatible with it.
I don't need to access any advanced function. Just switch to the AV channel. Incidentally if anyone knows of a way of doing this without a remote I'd also be interested to know. I've checked the manual and there doesn't seem to be a combination of buttons to do so...
Thanks!
Is your video player B&O? If so it should automatically switch to the correct channel.
If not, the manual says a video player needs to be connected by the 21pin scart socket.
It also suggests trying one of the AV programmes 33 or 34, can you get to those by stepping through the channels?
Stoobie
Exeter, Devon, UK
Hey Stoobie. Thanks for the reply. Just to answer in order to your questions:
- No, the VCR is not B&O but actually a Sanyo betamax.
- Yes, it is connected to the TV via scart
- No, I can step through channels but can't change the "program". It seems it defaults to Program 1 and thereafter I'm only able to switch through channels assigned to that specific program. If I use the antenna out of the VCR into the antennae IN there are maybe one or two channels where the "auto-search" stops because it thinks it has found "something" but it's just a lot of fuzz with a faint image of the tape barely showing through (strangely audio plays almost fine). "Fine tuning" in either direction simply loses the image altogether.
Hence why I was hoping even a cheap universal remote might allow me to simply change programme (no particular need for the other functions) but it seems it won't work so I started looking at B&O vintage remotes but before I splash out and find out it doesn't work I just wanted to make sure if all B&O remotes are backwards compatible. According to the manual the BEO4 should be compatible but it's also quite pricey considering that it has a million other functions I won't use... :P If there were any cheaper alternative or a button combination to switch Programs that'd be amazing but if not I'll just suck it up and get a Beo4.
If the Beo 4 works a Beolink 1000 will, too. That will be a cheaper alternative.
But I read here
https://www.beoworld.org/prod_details.asp?pid=708
that a video terminal remote is needed for an MX2000.
So you should verify that other remotes do work...
For sure someone on this forum will know.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I have a Sony Xperia Tablet that has a built in universal IR remote control and I have just tried the B&O options in there and that can control my Beosystem 1 TV so if you have a tablet or phone with an IR remote built in, that may be worth a try.
Failing that I might have a "chocolate bar" Video Terminal somewhere in my "B&O box" in the attic. You would be welcome to it if you wanted to pay the postage. They are quite heavy 😠 We will need to make sure it is compatible with your TV.
I am in the UK and from another of your postings it looks like you are in Australia so postage may not be worth it for you .
Stoobie
Exeter, Devon, UK
The MX2000 used standard remote control protocol's,unlike later remotes that used a higher carrier frequency,and more complex codes.
The Beo4,Beolink 1000,and later B&O devices won't control your MX2000.
A cheap universal,particulary say a One For All device will probably have the codes onboard,as they don't usually work with the later product.
Otherwise,as Stoobie mentioned,the vcr should automatically switch the tv to the av mode when selecting play,if connected with a fully wired Scart cable
Nick
Yes you will need the ”Mars bar” Video Terminal, none of the later Beolink 1000 compatible remotes will do a thing.
I’m not with my MX2000 right now, but I don’t think even the correct remote will get you anywhere with this problem. It doesn’t have an AV button as such. In the user manual, program 0 is stated to be for ”satellite TV”, but I seem to recall you can step to that from the control panel as well. So If it doesn’t work now, a remote won’t help.
The simple answer would be a proper, fully wired SCART cable as mentioned above. Then the switch is automatic, unless you have a very odd device that doesn’t supply the switching signal.
EDIT: I read the manual further. Program numbers 33 & 34 should switch to the AV input regardless of switching signals.
Hello all and thanks for the replies. Yes, there's no AV channel but all I would like to do is turn the TV to program 33 or 34.
I've looked at the manual for the beo4 and it does appear to list "MX models" under the compatibility list. Maybe a "limited" compatibility?
I'd be more than happy to go with the cheapest option available but just don't want to end up with a bunch of universal remotes none of which performing the basic function I'm looking to use. Any tips for things to look for in a universal remote?B
Btw, I have tried the scart option but my betaplayer must not output the control signal required for the TV to switch automatically. :(
NO! MX2000 (and MX1500) are completely different. See my answer above.
I reread your earlier post and it seems you are using the wrong buttons (tuning) when you should be stepping. I don’t remember what the actual button says and the manual doesn’t show it, but keep trying...
Hi Mika, thanks for the reply. I have tried for a fair while to find some sort of combination of buttons that would allow me to move through the programs but with no success. As you said, the manual doesn't mention anything in regards aside from saying that you can turn on the unit by holding the "tune" switch...
If anyone knows a way around it I'd love to hear it.
Cheers
