DLNA app for IOS with chromecast audio support
I have been mentioning this topic in a related thread (/forum/general-discussion-and-questions/nl-and-chromecast-audio#post-2080300), but worth to elevate.
With Chromecast becoming universally supported by most B&O products, I would be curious what apps for IOS colleagues are using to stream to chromecast. Spotify and TuneIn are obvious.
However, I have not found any good DLNA app for IOS that allows streaming to chromecast audio devices. VLC has still not implemented chromecast streaming. I dislike the GUI and UX of allcast, goodplayer or C5.
Would be curious to learn what others are using for casting DLNA to chromecast.
Deezer is also obvious...
DS Audio, the Synology NAS audio app. Not wonderful, but simple and it does the job...
Google Home, necessary to check if the streaming is still activated, and to be sure to stop it (I use a BS35 and a Chromecast Audio), and to create groups.
Thanks for your message. I checked out DS Audio and the clean interface looks good to me. However, description says that it requires a Synology NAS to run. Is this correct and/or is there some work-around? Also, I didn't see a notion that it supports chromecasting?
I know Google Home, but did not see that it has a DLNA controller included. Are you sure this is the case? Quick google search did not show.
The DS Audio app requires a Synology NAS (it's a proprietary app), and also the audio server running on the NAS...
And yes, DSM (Synology OS) supports Chromecast. Other NAS vendor may provide equivalent apps...
The Google Home app is not a player, it only allows the setting of the (chrome)casting (sorry for the misunderstanding).
Why not just use the - for ages - built-in DLNA renderer function in the B&O devices to stream from your DLNA server.
I use (or rather used to use) the 8Player or the good old PlugPlayer for that.
They also have support for AirPlay, if your setup should include 'non-B&O' AirPlay devices.
Maybe you are trying to 'group' your Google Cast devices (including 'nonB&O' ones) in order to get a multiroom solution?
That could reason enough for looking for a DNLA player, that has support for google casting.
I have been able to find one as of now!
DLNA and airplay are fine, but both do not allow to do multi-room. DLNA not at all and airplay only from itunes. So, chromecast with its multi-room feature is a lot more convenient
You have or you have not?
Just played from my NAS (a FLAC file) using the 8Player iOS app -> AirPlay to my BS Essence -> Join-in on my V1.
No problem!!!
AirPlay distribution over NL is supported since a couple of weeks.
Music Stream = using the DLNA renderer function of the Essence for distribution on the NL has been supported for long.
I thought your 'problem' is, that you have other Google Cast devices, that you want to use with the B&O devices....
...which is not possible using a DLNA app - not one that I know of!
Which means:
I should have written, that I have NOT - sorry!
Yes and no. all devices are b&o, but some of them are old (e.g., beolit 12), so i'm using a chromecast audio dongle to bring them into multi-room.
works well with spotify et al and i can play to all NL and "old" b&o devices.
pity that there appears to be no working solution to do so with dlna.
thanks for your replies.
I think the Glider Music Player app might do what you need: http://www.glideraudio.com
reads very promising. have you tried it? it "forces" me to link it to apple music, which makes me a bit suspicious.
