Hi... printing isn't a really big deal... international shipping is. I am in Denmark. I guess you are not. I honestly do not want to bother with it. I recommend you get 2pc printed locally. This will allow you to mount fins between the two.
DIY oak lamella/slats for classic Beolabs
Ok I’ll sort it out.
Hi @Ravsted,
would it be possible you share the stl files with us? I would love to "upcycle" my old Beolab 4000s to a new look.
Tim
Hi
I'm new owner of a pair of Beolab 4000 and I like the wooden option very much ;-))
Does anybody provide a .stl File for the Beolab 4000?
If so, please be so kind and upload or send as Email on request.
Thanks very much!
Kind regards
Christian
Hi Ravsted, Great work with the Beolab 1 3d printing. Is it possible to share this file with me too? I'd love to create this unique modern look for my Beolab 1's that I finally got working again. Thanks again , all the way from the "land downunder"
Don't worry Ravested, I found a link to the file on your webpage. Thanks again for the hard work! I'll have a go printing these off here in Sydney (I don't have a 3d printer but I'll get a company to do it for me) Do you know if the stl file on your webpage has been printed and tested? Or should I just get one printed off first and test it?
Hi
I created it for Del16 and he hasn't provided feedback yet.
So I don't know if it turned out as expected.
Print it with 100pct infill. This will allow you to slightly modify the printed part if needed.
Greetings from the country where the crown princess is from down-under. You and I are almost family 😁
Please provide feedback.
Hi Ravested, Nice work on the Beolab 4000s! I like your setup. I have a couple pairs of the speakers and would like to do the same. Unfortunately, I'm not having any luck finding the STL for the Beolab 4K you've made. Would you be able to point me in the right direction or could you share it with me?
Also, for your 'above the grille' test, what did you not like about the install? Was it the "raised" look of the lamellae or was it not attaching well to the speaker? I was about to model this myself.
Thanks!
<Delete duplicate post>
