Hi!
First I want to hear if someone else is having the same issues with the Avant NG as I have.
Second I want to hear if you have any ideas how to solve the problems.
So, the problem is that sometimes when I start the Avant with the selection of HDMI where an Apple TV 4K is connected half of the display is partly green with “old graphics”. The only way to get rid of this is to select an other HDMI-source and then switch back. Mostly it’s solved by then. However, this isn’t what you want to see when you turn on a B&O TV set. So I’m looking for a more solid solution.
What I have done so far is:
- Changed the Apple TV to a new.
- Changed the HDMI cable (4K)
- Changed HDMI connector on the Avant
- Changed to different UHD Chrominance (4.4.4 - 4.2.0)
None of these actions seams to help.
Have you the same issue? Any ideas?
Best regards Ola
