Disney Plus App on BeoVision Eclipse
thanks Fansastic for trying and your feedback. I will contact the support again, but I have little hope that they (are willing to) understand me.
News from B&O Support
Quote: "We have received a message from our team in regards to your inquiry. Our headquarters are looking into the situation and they are working on a solution. For the time being it's difficult for us to determine when exactly the issue is going to be resolved, we don't have estimated time. If you have any additional questions, do not hesitate to contact us back. "
Great news! Thanks for sharing
I know there's a couple member of my family that would be very happy to see this.
Hallo
I realised I joined this club as well
my brand new BEOVISION ECLIPSE 65 does support all apps ( AMAZON, NETFLIX....) but no trace of Disney +.
I contacted B&O e was invited to contact LG. Lg sent me nack to B&O.
Last B&O statements is indicating a not clear issue at software level and that they are working on it..
I admit I do not know the architecture of WEBOS and the special needs of Disney, but I am extremely surprised of the entire story ( By the way another missing APP is APPLE TV).
Regards
I dont think that the webos in Eclipse, will ever recieve apple tv app.
And Alfio, if you want to make your experience much better, I would recommend buying an Apple TV and control it with the PUC control.
You will not find a better userinterface for your apps.
Thanks for the feedback Indeed I have alredy a Set top box unit ( an NVIDIA Shield) but my plan was to avoid it. I quoted APPLE TV as another example of missing APP in what is presented as LG WebOS. By experience set top box limit the streaming to HD ( even if 4K capable). I have an application called Infinity TV ( Italian pay per view) that works on 4k only if on TV. By the way it works ( even if there are limitation on the location set-up). Regards
Hi all. Any updates on support for Disney+ on eclipse mk1? I have also not managed to find the app on the lg app store.
I don't understand how Disney states it supports the app on all webos version 3.5 and higher. Is the webos that B&O has different authorizations for app? I thought the eclipse was just a C7 from software perspective except the sound settings.
Can Disney or LG block apps on beovisions?
