Heritage wrote:
I had email contact with the B&O Support. Their answer was not conclusive for me.
Quote: βWhen it comes to the Disney Plus App, the developers of the app did not make it compatible with WebOS 3.5, thus, the app is not compatible with the operating system of most modern LG smart TVs including the BeoVision Eclipse. The development team have tried and found that this cannot be rectified. We recommend using an Apple TV or other set-top box to access the Disney+ app, or reaching out to the app developers for further information.β
Particularly because on the LG Web is noted that Disney + should run under WebOS 3.5 and the C7 is supported :
https://www.lg.com/us/support/disney-plus-lg-tv I'm at a bit of a loss.
That is a strange answer indeed. This needs more clarification by B&O support. Did you send them this feedback?
This morning I could not acces the Content Store, will try again. Maybe the app has been removed by LG? Not sure if the Eclipse is getting same content as LG C7 owners. I do not use Disney+ but shall look if the app is still working.
This is a continuous problem with B&O, they team up with another provider/brand but after short while all kind of restrictions occur for the B&O owners. Think of Spotify, Netflix & Android on the BV14/Horizon/Avant NG, and now with Deezer on the Harmony and of course B&O own Multiroom platform. They are an expert of setting themselves out of the game!
This Disney thing is same problem, there is some kind of restriction between LG/B&O and you are limited as user. Unacceptable for the Eclipse platform, as this was promised to be future proof due to the LG OS...not...
Keep pushing B&O support!
