Disassembling a Beocom 6000 wall charger
Hi, I'm trying to do a hidden installation of the wallcharger by drilling a small hole through the wall into a wardrobe on the opposite side.
How do I disassemble the wall charger? I do not want to make a hole big enough for the power supply.
I guess I could just cut the cable, but I would prefer to disassemble the charger.
Thanks, Peter
Hold your horses!
I've done this without any dissassembling or cutting. I used a plastic pipe (in Swedish "VP-rör"). There are two types of VP, link and
Hi, they must have changed the design.
The cable now goes into the charger through a small hole on the back.
OK, then I would just cut the cable and use a "sockerbit" to reconnect it again in the wardrobe.
Yeah, propably the best thing to do. The leads might actually be soldered to the pins inside the charger.
I may be wrong on this one, but at some point the connection from the cable and into the power supply was indeed a plug... By using a bit of strength you could turn it 90 degrees counter-clockwise and pull it out of the power supply. I would estimate this plug to be approx. 8 mm in diameter.
I'm not sure if the charger still is made this way, but it is worth a try.
You are right! It is a plug. I never looked at the power supply end of the cable.´
Thank you both for your help.
/Peter
