Hi all.
New here, just got a Beomaster 3000-2 and wondering anyone knows of a DIN switch to be able to increase the number of connections? I found an old thread (from 2008!) but the links had gone.
Thanks in advance
Mark
Hi all.
Thanks in advance
Mark
Hi and welcome to Beoworld!
If you want to connect B&O equipment you will need the full 7 pin connections to allow datalink (hence control other input devices). B&O used to make such a device, and they sometimes come up on eBay (mine was about £15 a few years back). Here's a picture: link
But if you are adding non-B&O stuff then something like this is ideal (from our site sponsor!): link
EDIT: If it's the 1970s Beomaster 3000-2 then I think the DIN inputs only have five pins, hence the second adapter above will be fine!
Thanks Guy.
It is the 1970's version with the 5 pin DIN, i will check out the second link.
all the best
Mark
B&O also made very small adapters giving you a switchable 5 or 7 pin din and a cinch input.
So you can switch between a 5P din or a stereo cinch on a 5P din input.
I have several of those still, feel free to PM me if interested.
