Digital Power Link - What is it and what to do?
Hello Beoworlders, In a few weeks, BL50 will be delivered and I'm thinking about the best way to connect them to a Core that I already own. I would like to have a direct digital path between the NAS hosting music files and the speakers, in order to avoid multiple DA/AD conversions and let the 50s do the job. Looking at the specs, I noticed that Core has a DPL plug and that 2 DPL plugs are present on the Master BL50. Could I use them to connect Core to the 50s (they would be connected to a Theatre through regular Power Link) ? On another point, I noticed that Core is limited to 24 bits/95 Khz on it's optical output. Is it the same for DPL ? Thanks for your help, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
  The DPL port does nothing - is for ‘future use’. When or if this ‘future use’ will be available, is not known Please also have a look here: The DPL port on the BL50 is for inter loudspeaker communication only. As for digital inputs, apart from the USB audio input you have two SPDIF inputs - coax and toslink. The optical input supports up to 24/96 - which is what the Core will output via optical. MM
