Difference in Bv1 models
  What are the differences between the bv1 models? bv1, bv1L, bv1LS?  Cheers Nick
BV1 No Masterlink
LS Have masterlink and  L have Masterlink. Not to sure about the difference here.
LS is Link Slave. Used as bedroom or similar slave TV when linked.
"LS": Could be used "STAND ALONE" or as a "LINK SLAVE" to acces sources of a "MAIN-TV / AUDIO System"
  via ML/Antenna.
"L" :  If equipped with a ML module it could be used either as a "LINK SLAVE" (V-Opt 5/6)  or as a "MAIN-TV"
(V-Opt 1/2).
"L" : If equipped with an optional modulator module HF distribution to Link-TVs was possible.
Oh well I have a 1 without that.
Does anyone have a ML module that would go in a BV1, as I'd like to hook it all up
thanks for the replies, the reason I ask is I bought a bv1 which i believe was a ls set and so did the seller! It turned out to be a bv1 with masterlink module.  I have a bv1L in my bedroom aswell. So am I worse off or better off? I noticed the bv1 has powerlink sockets my bv1L hasn't.
Cheers Nick
I have one of the later models, with no ML module build in, but a ML socket. Took some time to figure out that I had to get the module and the socket was without function. Nice! But installing the module was quite easy.
The earlier models can not be upgraded.
These are a surprising amount for a small PCB - about £175UK as I recall.
Plus fitting - unless you do it yourself.  The link board just clips into a multipin holder - rather like fitting PC memory.
