Difference Beosound Stage with LG C1 panel and Beovision Contour
Is there any difference in the control possibilities with a BeoRemote One of a Stage with LG panel in comparison with a Contour? Or are they identical?
Will a Stage with LG panel become a “Beovision” on the BeoRemote One?
There are no difference in control possibilities.
The Contour like the Stage will not allow for connection to multiple other speakers, and that’s the control differences you get with the other Beovisions.
With the Contour, you’re getting a superior design and also more stand options which makes it more of a Beovision than the separates.
