dba buying in DK
Hi
as i'm not from DK and i wish to buy something on DBA ca anyone inform me if there is EN version of that page ?
Not that I'm aware of.
any suggestion ?
I can see tel. number ..but no contact mail on the ad.
Did you try calling the seller?
Den blå avis was bought by ebay years ago, so don’t expect any english version of dba.
There is an internal message system there - that should be enough for contacting in the first place.
Some sellers will then give you your email adress.
P.S. Personally I would not want my email adress to appear on a public site!
‘Some sellers will then give you your email adress.’....means ‘.....their email adress’.
Regarding that i do not know where to klik on the page ...hmm
Maybe i need to register first ?
Yes, you will need an account.
I just checked, You should be able to navigate using the translate functionality in Chrome.
Anything in particular you are interested in? There are a few tricks and prices are all over the place.... 🙂
You need to registered to start chat with sellers on dba.dk. For registration you need postal adress with ZIP code in DK.
