Dark picture on BV4 with SW 8.05
Hi all
Just a heads up, don't update your BS3 SW to the latest version(started from 8.05) if you are using a BV4 Plasma screen. I had mine upgraded, and since then, the picture is very dark when turning the tv on, i can get the picture to its normal self again with either one of 3 methods.
1. Placing a hand on the lightsensor for aprox 5 seconds.
2. Running Automatic Color Management manually
3. Adjusting the contrast setting in picture menu(by one click), this doesn't wotk always.
SW 8.12 has not solved this issue, so i must wait until the next SW is released.
/Weebyx
Hi!
Same thing for me.
My dealer flashed my BV9 yesterday with sw 8.12 and it did not solve the problem.
He checked in the B&O intranet, this problem is mentioned in the "known issues" section... without any delay for correction of the default and no work-around.
We have to wait, unfortunately.
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Does this "dark picture" occur on Beovision 7-40 (markIII and markIV) and 7-55 also with sw 8.xx???
Regards
i experience(when upgraded to 8.XX software) the same bug on my BS3 with Bv 4-50 bezel front.....no solutions?this is not admissible
No solution yet, i have written directly to B&O and they have not responded yet !
Maybe if we all wrote to them ?
/Weebyx
I have been in contact with my dealer today, and a new SW fixing this problem is expected in about a month from today, they offered me a service release which is basically a Beta version, but since i have to drive 600km to get i flashed, i will wait until the final release :)
/Weebyx
My BV50/BS3 was updated with the latest sw (8.xx) when it was installed a few months ago and I thought it was dark as well, but since it was a new TV to me...I didn't know that it was not supposed to look that way! I hope we get a sw fix soon, thanks Weebyx.
Not a problem on a BV7-40 Mark 3
I experience the dark picture bug also in the version 8.12a of my Beosystem 3 just updated.It's random,sometimes clear imagine,sometimes dark,i noticed it happens also during watching tv!!!!The funny things is that when the technician came it was all ok....
I think It's something about the contrast,when i go to modify it,it repair the bug screen..
I'm really disappointed.....any suggestion?
My BV4-65, purchased november 2009 have had same kind of problem. The picture is a little bit dark and some details in movies are missed. Sometimes it suddenly appear brighter and what a marvellous picture it becomes. I am told they are working on it and the problem will be fixed in about a month.
Ahmet1
