Create PUC for Beosystem4 based TV
Can this file be used in System 4?
the file name maybe *.decx ?
All of the more recent products use the .decx file format which is different to the older .dec format used with the masterlink era BeoVisions and BeoSystem 3 for example, so this file will not work with the BeoSystem 4.
Martin,
Thanks.
Anyone have new PUC for Panasonic Tv's ?
Is there any documentation regarding the older format for Beosystem 3 PUC?
Can I upload it via an USB stick into a Beosystem 3, too?
Very interesting topic!
Anybody can provide system4's PUC for Panasonic TV ?
I can't get it in my country.
The attached file works for the Beovision 4 Plasma screens (which is Panasonic panels). Rename the file from .txt to .decx
I do not know if they work for Panasonic TV also, but you could always try.
Thank you very much.
I will try it.
Thank  lano .
This file can be read by system 4, but can't use to control TV .🙁
Anybody have Panasonic TV PUC for system 4 ?
