Create PUC for Beosystem4 based TV
It is possible if you know what you are doing.
You need to have a good understanding of how IR protocols works in general and of the PUC file syntax.
Custom PUC files can then be uploaded to the TV using an USB stick.
I need a PUC file for a Beovision 4. Actually just to turn it on and off with Beosystem 4What box do you need a puc file for, or what do you like to modify on a specific puc file?
The BV4 panels are controlled via RS232 connection. Only the very latest BV4 are supported by BS4. I don't think that a PUC will help you that much.
Why shouldn't a PUC help? All I need it to is to turn the monitor on and off. It works with a Panasonic remote so why shouldn't it work via PUC?The BV4 panels are controlled via RS232 connection. Only the very latest BV4 are supported by BS4. I don't think that a PUC will help you that much.
Ok. I wasn't aware of that this trick is possible with all BV4 screens.
I think there is already a Panasonic screen PUC in the database.
If you can't find it with the search function within your BS4 maybe ask your dealer.
