Hi All,
Just got a couple of questions that someone may be able to help with......
1.  Can you connect a BeoSystem3 to a a BV7-32?  I have an BV7-32 with HDMI, but want to connect more than two HD sources to it.  I know I could use the Gefen switcher but I also would like to hide away all my sources and minimise the wires coming from the TV.
2.  Has anyone swapped a Beoloab2 for the Beolab11?  Do you miss the BL2 - I think the BL11 is aimed as a lower option to the BL2, but its slightly smaller size and design I like more than the BL2, but I was amazed the difference the BL2 made to my setup when I added it, but its a smallish room its in and sometimes it does sound a bit too much watching an action film, so think I could get away with lower power, just wondered if anyone had gone that route?
Thanks,
Chris.
