Could I combine BeoLab 8 with BeoMaster 901?
Hi! I used to "in the know" about B&O, but I'm not anymore. I know you are though :-)
My BeoSound 4 has died on me. It is good looking, but it never gave me much joy anyway - more grief. So, I'm thinking of hooking my BeoLab 8's to a more vintage control unit.
  • Could I combine BeoLab 9 with BeoMaster 901?
And would I get away with it? I mean would it work and play well? The BM 901 has an integrated 2x20w amp, and my BL9s are active. Would that be OK?
What would be a good alternative, if not?
Thanks!
Kim
Hi Kim
Please don’t worry, these items are plug and play, full instructions are included.
Kind regards Steve.
Thanks Steve!
And what exactly was it that you'd include as a freebie, if I put in a not on the order like "(Please add a note note to request a couple of free 2 pin DIN plugs and I will be pleased to include these for you)."
Aren't they on the
Hi Kim,
The leads that you mentioned in your most recent post will not work with Beolab 8000 speakers, they are for Beolab 3 or 9 speakers instead.
Kind regards, Steve.
