While working on this unit and I was glueing on the frame were the main screws that secure the face to the body. I got super glue on the smoked plastic front panel. I sanded up to 4000 grit sandpaper and buffed it with plastic polish. I still have a small area that is cloudy. Any suggestion on how to fix it?
Cosmetic issue on Beomaster 6000
You could try t-cut (car polish) I have used on various decks and has worked, but it may be just as your plastic polish
Hope this helps
Taπ
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
