Cosmetic issue on Beomaster 6000
While working on this unit and I was glueing on the frame were the main screws that secure the face to the body. I got super glue on the smoked plastic front panel. I sanded up to 4000 grit sandpaper and buffed it with plastic polish. I still have a small area that is cloudy. Any suggestion on how to fix it?
You could try t-cut (car polish) I have used on various decks and has worked, but it may be just as your plastic polish
Hope this helps
Ta😁
