Core software: UPDATED 1.9.41629
All, my Core updated its system software last night from 1.7.37078 to 1.9.41629.
I have no idea what the updates did (I couldn’t find update notes) but thought I would post as an FYI.
Cheers!
My BS2, Essences and M3 have an update waiting for them.  I usually wait a week or two before I apply updates to make sure nothing important breaks or gets turned off by the release.
Same here. While updating my BS 1 and M5, I noticed B&O ended up dating all my speakers including the Cores to 1.9. I didn't notice any changes either other than the numbers.
I am waiting for B&O to add the image for the Core to their widget. It's the only modern product I think that does not have an image.
No update on my Core yet.  Hopefully the update will fix a problem with my favorite Tune In station that was fixed with the Essence and M5 updates.
Hopefully the last update will solve a BS Core issue that started with software 1.7.x in March 2020 where the Core is sending a beocore_tcp unsubscribe after the automatic daily reboot which makes it unable to participate to Beolink multiroom unless it is restarted.
More info in the coming days!
Reset my Core and the update appeared. Previous problem with a Tune In station is gone. All is working perfectly again. 😀
Nice! Enjoy the weekend with some music, then!
