Hi all,
I have some outdoor speakers and in order to keep them in the "link" system, I have the following setup.
A Beosound Core is connected to my network via Ethernet and to a Beolink Passive amplifier using a Powerlink cable (RJ45 on the Core side, DIN on the Beolink Passive side). Then two conventional speaker cables go to each of my waterproof passive speakers outside. Then I can play any source from the my B&O equipment or stream some Spotify music via the Core. Everything works very well, except that every so often, it does not work. Everything in Spotify looks like it is playing normally, but it does not.
In order to make it work, I have to unplug the Powerlink cable DIN connection on the Beolink Passive and plug it back, then I hear the "click" that means that the Beolink Passive amplifier detects some input and switches on.
I don't think the problem comes from the Beosound Core side as I have connected a pair of BL3 to it instead of the Beolink Passive and it worked fine for a few weeks, and I never have any problem with it in this setup.
I also swapped with another core and i have the same problem. This leads me to think it is not a Core problem...
Any ideas? Dodgy or wrongly configured Beolink Passive ? Some setting to enter in the Core?
Thanks.
Regards,
Christian
